odforce thread [forums.odforce.net]
Original post:
Can someone fill me in on why the scheme in the attached file doesn't work? Basically, I'm using a wrangle to do some point cloud searching. I want to switch the searched geometry based on some attribute on the wrangle's input geo. The vex for that looks like this:
float radius = ch(“radius”);
int npts = chi(“numpts”);
int handle;
if (@side > 0) {
handle = pcopen(@OpInput2,“P”,@P,radius,npts);
} else {
handle = pcopen(@OpInput3,“P”,@P,radius,npts);
v@Cd = pcimportbyidxv(handle,“Cd”, 0);
i@num = pcnumfound(handle);
pcclose(handle);
I'm guessing that my implementation doesn't play nicely with the way that vex / point clouds parallelize, or something. The result is that half of the points don't find any matched points at all (pcnumfound gives 0).
The attached file demonstrates it visually. The code above (node “pc_broke”) results in half of the points failing to find matches. If I use the same search geo for both groups (node “pc_works”), then all points find matches. And if I do it in two wrangles, each constrained to one group of points and one search geometry, I get the desired result (node “CORRECT”).
Removing the pcclose() has no effect, btw.
