I've generated a shadow map from a light, and inside a point vop I'm trying to use the shadowmap vop to put point color attribute “shadows” onto some geometry by piping its output into Cd.
I can't get it to work at all. Is there a trick to using this node?
Also, what is the XDSM Channel? (I assume some sort of deep shadow map channel, but the documentation doesn't even mention it.)
