Diffrence between attribute vop and vopsop?
   3958   2   0
hi. what is the diffrence between this two nodes? can i do everything in vopsop as i do in attributevop?
You have probably figured this out already but in case you havnt: the attributevop is basically vopsops successor.
-b
http://www.racecar.no [www.racecar.no]
The VOP SOP is a specific context for modifying point attributes explicitly. You can not add or destroy points. It has been hidden from the tab menu as you are encouraged to use the newer Attribute VOP SOP.
The Attribute VOP SOP is a general context for adding, modifying and removing point, primitive, vertex and detail attributes.
