how do you setup render layers for pyrofx? I am aware of the extra image planes for the mantra rop but not sure how to add fire/smoke/vol light…
thanks !
pyrofx render passes
5721 5 0- James Rowe
- 38 posts
- Sugleris
- 30 posts
Hey James,
Inside the pyro shader there's some outputs you can pull directly into your image planes.
Create a new image plane and under Vex Variable put in “smoke_mask” and
set the vex type to “Float”.
set the sample filter to “Full Opacity Filtering”
Repeat this for “fire_mask”
Once you have a volume light / other lights rendering with the volume just make a third image plane called “all_volume” and under Light Exports set it to “Export variable for each light”
The older pyro shader had two other built in outputs called Fire_color and smoke_color but now its just fire_mask and smoke_mask. If you think you would need those you could always export those out of the shader to bring into an AOV.
Cheers!
Nico
Cheers!
Nico
Edited by Sugleris - May 31, 2016 16:58:49
Shortcuts are supposed to be hard, if they were easy then they would just be “The Way”.
- James Rowe
- 38 posts
- James Rowe
- 38 posts
- James Rowe
- 38 posts
- Sugleris
- 30 posts
