LookAt down one of the World axes?
   4056   5   2
Is it possible to force an object, a child of some hierarchy, to always look down one of the World axes, Y- for example? I already figured a way of doing it with a lookAt object (with blend ObjNode and a single translate axis enabled), but I bet there's a more elegant way of accomplishing this.
Think of a crane with a rope and a hook hanging from the end of its arm. Whenever the crane's arm rotates up or down, the rope always should point downwards, at the ground.
Edited by ajz3d - June 24, 2016 20:05:49
Did you ever find a solution to this? I'm trying to do similar (also modelling a crane actually) and have no idea how to do this.
I'm trying to keep a crane at the origin, and allow the central column of the crane to rotate around the Y-axis.
I'm trying to drive the central rotation of the crane using a box (the object the crane is carrying) in space which moves along a curve, so I want the crane to turn and face the box.
Any ideas?
The look-at constraint chop allows selecting any of the cardinal directions (+/-) for the look-at and look-up axes.
jsmack
Thanks but I'm not getting it to work…
In the case of the screenshot, you'll see the y-position of the sphere is zero. I want to be able to adjust the y-position of the sphere, but somehow lock the rotation of the cube as it would be if the y-position of the sphere was zero.
Changing the look-at and look-up axes only seems to flip each axis 180 degrees, so doesn't appear to do what I need.
Edited by cmbn - Feb. 6, 2018 15:07:29
Screen Shot 2018-02-06 at 20.00.27.png (1.4 MB)
does this work for you?
I added a Blend Constraint and blended in only the ry from the lookat
Edited by goldfarb - Feb. 6, 2018 15:11:52
single_axis_lookat.hip (96.1 KB)
Training Lead
www.sidefx.com
arctor
Perfect! Thanks so much!
