How do I save a texture from a opdef:/Object path to my local filesystem?
   7683   4   1
How do I save a texture from a opdef: /Object path to my local filesystem?
I am able to add opdef: /Object/simplefemale?color.flattened.1001.jpg to a Grid object using uvflatten by using a shader that uses that image mapped to it.
But how do I save that texture jpg to a file on my local file system?
Edited by CreateTheImaginable - Aug. 11, 2016 00:58:34
Just render it, top down with the camera aspect ratio matching the XY grid size.
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
It's possible to extract the internal file's contents using HOM and write it out to wherever you'd like. There are two different ways to access the files:
Query the asset definition for the “section” (everything inside an asset is stored in named thing called a section) and just get the contents and write it back out
>>> s = hou.node('/obj/simplefemale1').type().definition().sections()["color.flattened.1001.jpg"]
>>> with open("/tmp/color.flattened.1001.jpg", "w") as fp:
...     fp.write(s.contents())
The hou.readFile() function can also understand opdef: references so you can do that as well.
...     fp.write(hou.readFile("opdef:/Object/simplefemale?color.flattened.1001.jpg"))
or just save it to file through the Type Properties…
1 - select the section (that's what these things are called)
2 - save as file
Training Lead
www.sidefx.com
Thanks to all 3 of you for your solutions! I am going to try all 3 just to learn more about Houdini!
