Hi There
I'm using Houdini indie 15.0.416 and just noticed there are two different fluid source nodes.
If I use the shlef to create an emitter say it uses one type but if I add a fluid source node it adds a different one.
In particular the noise options, one has curl noise and the other has noise?
Is this normal?
cheers
Nigel.
two different fluid source nodes?
1134 0 0- nigelgardiner
- 48 posts
