Having trouble when there is two (or more I gess) unified noise in the same vop, the parameters do not promote nicely.
Doing nothing before promoting the second noise parameters result in a mess.
Putting all the parameters of the first noise in a folder at sop level in the “edit parameter interface” result in random corrupt parameters in the second noise i.e. output range toggle not expanding the necessary parameters or duplicates of parameters not in the noise node)
Promote multi unified noise parameters
1027 0 0- NAHASSIA
- 125 posts
