hi,
is there an official list of which MEL and Python bindings are available to control an asset via script?
any input welcome!
MEL and Python bindings?
3807 2 1-
- deadalvs
- 196 posts
- awong
- 818 posts
The plugin just provides two MEL commands: houdiniEngine and houdiniAsset.
You could use the help command to see the flags:
For simply changing parameters, you just need to use
These can be run from Python by using `maya.cmds` and `maya.mel`.
The plugin also uses several MEL scripts that can be found in the
help houdiniEngine
help houdiniAssetFor simply changing parameters, you just need to use
getAttr, setAttr, and connectAttr. For sync'ing to create output nodes, you'd need houdiniAsset -sync myNodeName. These should cover most cases.These can be run from Python by using `maya.cmds` and `maya.mel`.
scripts directory, but they are more for internal use.
Andrew / アンドリュー
- deadalvs
- 196 posts
