Where did the Group by Numbers and the Pattern options go?
   14485   6   1
Just watching the Group tutorials by SideFX and I'm seeing that the Group Create node doesn't have these same options.
Thanks for any direction you can give!
The Group Expression node only works with VEX expressions. What is the direct replacement for Group by Pattern where I can use ‘0 $N’. I tried putting it into the Base Group section in the Group node to adjust edges (as per Rohan's Mograph Tutorial) and it only scales 1 edge opposed to 2. Any suggestions?
instead of using $N i think you could use
`npoints(opinputpath(“.”, 0))-1`
also there is this vex snippet for selecting end points by checking how many neighbours the point has:
@group_ends = (neighbourcount(0,@ptnum) == 1);
just add group_ends to the attributes to create and it will create a group.
hope it helps.
edit: you can also use
in the groupexpression SOP.
or:
@ptnum == 0 || @ptnum == @numpt-1
to simulate the 0 $N
Edited by Doudini - Feb. 25, 2017 22:07:18
What is the desired end result? I thought Group Range was the replacement.
I am also looking for the group by pattern number node in order to take a point with a 0 number and make it into group C so that it may be copied in a 360 pattern with a copy stamp for another one of Rohan's (Tea and Cookies) tutorials.
Rohan describes changes to group nodes… https://vimeo.com/209767952 [vimeo.com]
