Hey guys ,
I'm doing some RnD to achieve a underwater explosion .
I found this reference : Your text to link here… [youtu.be]
I was wondering if any of you has some advices on how to achieve the same effect .
I was think of adding Viciousity on my pyro . But the part i'm not sure how to do , is when the explosion comes back and then turn into smoke.
thank
Underwater explosion
5378 2 0-
- Abdou Sako
- 3 posts
- Enivob
- 2658 posts
I love slow motion stuff.
You may want to simply try to create the setup shown in the video.
Create a FLIP tank.
Then use a metaball to create a bubble space inside the tank that grows and then quickly shrinks.
Inside the bubble area of the tank create a pyro sim with an animated fuel burn that matches the grow shrink of the bubble. The inverted normals of the bubble should also be used as a collision object for the pyro sim so it can not escape the bubble area. It also looks like as the bubble collapses the temperature is increased again a final time, probably due to compression, because the water can not transfer the heat fast enough to other parts of the tank.
Once the bubble collapses, add a smoke sim at that same location.
The trick, of course, will be the rendering and materials as well.
Create a FLIP tank.
Edited by Enivob - May 20, 2017 21:16:55
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
- Abdou Sako
- 3 posts
