Move multiple 'copied' objects along a spline
9014 13 4-
- reelinspirations
- 178 posts
I have a spline that I've copied a bunch of spheres to, but I want to ‘move’ the sphere's along the spline.
I know how to set up a single object to follow a spline, but have no clue how to make this work.
For those who know Cinema 4D, what I'm trying to do is ‘clone’ a bunch of objects to a spline, then use the ‘offset’ to animate them along the spline.
Jim
Jim
- friedasparagus
- 402 posts
- reelinspirations
- 178 posts
- r_ross
- 22 posts
- druitre
- 65 posts
- sepu
- 474 posts
- mestela
- 1867 posts
- druitre
- 65 posts
- plazadelmar
- 27 posts
mestela
same but different, using the attribute interpolate sop, plus a slider for randomness.
If I take this example and use copy to points to have many splines, Attribute Interpolate brings all objects to 1 spline even though I have many copies. How can duplicate it, keep the points and position of the splines?
Edited by plazadelmar - Dec. 12, 2018 10:00:11
- tamte
- 9492 posts
- plazadelmar
- 27 posts
- plazadelmar
- 27 posts
- tamte
- 9492 posts
plazadelmarline 3, change
I would like to each spline to produce random speed for the spheres I
t = @Time * ch('speed');to
t = @Time * ch('speed') * fit01(rand(@primnum), .5, 1);which will multiply the speed of each sphere by random number between 0.5 and 1 per curve
Edited by tamte - Dec. 12, 2018 14:33:09
- plazadelmar
- 27 posts
tamteplazadelmarline 3, change
I would like to each spline to produce random speed for the spheres It = @Time * ch('speed');
tot = @Time * ch('speed') * fit01(rand(@primnum), .5, 1);
Awesome. Thank you
Edited by plazadelmar - Dec. 18, 2018 12:55:10
