Slow down cached FLIP sim
   2275   1   0
Hi there,
I've cached out a FLIP simulation (with particle IDs enabled) to a .bgeo.sc sequence. I need to slow down this sequence so I'm attempting to use the Orbolt TimeDrive asset which is sort of doing the job.
Time drive works well when I speed up the sim to greater than 100%, but when I slow time down to 50% then I get a weird jumping in the position and scale of the sequence on every off frame, despite the fact that the points are moving correctly relative to each other.
Any tips or pointers would be greatly appreciated!
Thanks.
I was going to delete the topic as the answer was so easy, but this might help someone in the future. Use an Unpack SOP on your cached files before using Timedrive and it works!
