math q: director vector to spherical coords
   3475   5   1
Not strictly Houdini related, just a question from the mathematically challenged…
How can I convert a direction vector from cartesian to spherical coordinates?
I know the formula for a *position* (as well as the nodes topolar and frompolar) but not a vector… it's probably something simple that I'm overlooking…
Jon
Isn't a position just a vector, as well?
I'm not sure…
Direction vectors must be treated differently when doing a space transformation, so I assumed that applied to this as well.
wikipedia says
In mathematics, a spherical coordinate system is a coordinate system for three-dimensional space where the position of a point is specified by three numbers: the radial distance of that point from a fixed origin, its polar angle measured from a fixed zenith direction, and the azimuth angle of its orthogonal projection …
so you are missing two variables no, distance and azimuth angle
Head of CG @ MPC
CG Supervisor/ Sr. FX TD /
www.timucinozger.com
A direction vector is also a position on the unit sphere. You can use topolar for a direction vector, and it will return phi and theta, with r being the length of the vector (one if normalized).
Thanks, easier than I thought! And now makes more sense.
