I would like to make an animation where a logo swimming in the ocean then jump out from the water. First I made a logo what follows a curve path, then I add a flattank which follows the text. When the text reaches it's end point it stops and jump out the water from that point. First I didn't know how to make it jump. But then I created another object on that point and animated it. But it doesnt collide with the flattank. If I add another static object in flattank_sim the text dissapear immediately. Itried it with switch but doesnt work either. Don't you know how can I add the second text object to the scene and make it collide with the water? Thank you
Can't switch between two text objects
1390 1 0- egygabor
- 23 posts
- scottval
- 56 posts
I think it would probably be easier if you just had one text object, and made it jump out of the water. I think adding the second object might be making it more complicated than it needs to be. I think you should be able to make the text follow a different path, at the point where you want it to jump.
-Scott
-Scott
