How to delete polygon primitives but keep edges?
   35143   6   3
Like the title says, trying to keep only the edges and points of a geo. What would be the best way to go at it please?
A.
Ends sop, set ‘close u’ to ‘unroll’.
Cheers, just watched some Entagma video about loops and subdivisions, great stuff, and he's using it. Works like a charm. Thanks a lot.
A.
Edited by Adriano - Aug. 12, 2017 00:08:55
Another way to do it is with Poly Cut with parameters set to
Cut Points: *
Strategy: Cut
it's probably time to make an edgesSOP - aka before NormalSOP you had to use a facetSOP…
you can also use Convert Line SOP, especially if you want to avoid double edges
There is also the "Labs Edge Group To Curve geometry node" Which helped me to get just the edges
