How to check if a valid licence was found
4430
2
1
Oct. 5, 2017 11:02 a.m.
Hi!
First question
In the Licencing page :
Licensing for Houdini engine 3.0 [
www.sidefx.com ], it is stated that the licence is checked when loading an asset or creeating a node.
Is there a simple way to check if a valid Licence is found before these calls to functions?
For example : HAPI_IsValidLicenceFound()
chrisgreb
Oct. 5, 2017 11:40 a.m.
Yes, and here's some code to check the license:
bool
GetLicenseType ( FString & LicenseType )
LicenseType = TEXT ( "" );
HAPI_License LicenseTypeValue = HAPI_LICENSE_NONE ;
HAPI_GetSessionEnvInt (
MyHAPISession , HAPI_SESSIONENVINT_LICENSE ,
( int32 * ) & LicenseTypeValue );
switch ( LicenseTypeValue )
case HAPI_LICENSE_NONE :
LicenseType = TEXT ( "No License Acquired" );
break ;
case HAPI_LICENSE_HOUDINI_ENGINE :
LicenseType = TEXT ( "Houdini Engine" );
break ;
case HAPI_LICENSE_HOUDINI :
LicenseType = TEXT ( "Houdini" );
break ;
case HAPI_LICENSE_HOUDINI_FX :
LicenseType = TEXT ( "Houdini FX" );
break ;
case HAPI_LICENSE_HOUDINI_ENGINE_INDIE :
LicenseType = TEXT ( "Houdini Engine Indie" );
break ;
case HAPI_LICENSE_HOUDINI_INDIE :
LicenseType = TEXT ( "Houdini Indie" );
break ;
case HAPI_LICENSE_MAX :
default :
return false ;
return true ;
Edited by chrisgreb - Oct. 5, 2017 11:41:36
Oct. 5, 2017 1:17 p.m.
chrisgreb Yes, and here's some code to check the license:bool
break ;
break ;
break ;
break ;
break ;
break ;
default :
return false ;
return true ;
Thanks for the answer!
I can now check the licence. But in fact, I really need to load an asset or create a node before being able to check it correctly.
Thanks again for the quick answer.
