Growing curve on object
   2479   2   0
Hi!
I have an animated polygon and I'm trying to find a way to create a growing curve on this object. Some methods that I have tried do not work on animated polygons (the curve stays behind). Can anyone suggest what I should use to create a procedural growing curve which would stick to the object?
Thank you in advance!
There's different ways of going about this.
Also, do you want just the part of the curve that is attached to the animated polygon or the whole curve to move in tandem?
Attach a hip file and maybe one of us might be able to offer a suggestion/example.
Thank you for answering!I found that Drawing Curve node can project the curve on the object UVs so the curve will always move after the object.
