Fill object with particles
5812 2 2- plazadelmar
- 27 posts
- Sean Rowe
- 39 posts
Yep!
1 - Convert your original object into a volume with an IsoOffset node
2 - Scatter points inside your volume with a Scatter node with how many points you want
3 - Convert your points to VDB with a VDBfromParticles node, you'll have to adjust some setting to make the SDF visible.
4 - Convert to a mesh with a ConvertVDB node set to Polygons.
You may need to adjust the shape of your VDB before you convert it to polygons. There are a bunch of nodes you can use like VDB Reshape, VDB Smooth etc
- plazadelmar
- 27 posts
Sean Rowe
Yep!
Thats is an swesome trick. Thank you for sharing.
II think the first two bullets did the trick. Now I need to figure out how to use it as particles and use it with colliding geometry. So far I emitted particles from points and use collider object to interact with it. Didnt work yet as I was hoping. Its a process
