FLIP Solver flow rate
   1361   1   0
Hi, i'm trying to create some lava emitting from an cached animated geo.
i'm using FLIP Fluid to emit the lava and now i want some areas to turn off or emit less Lava. the best working solution I've had has been to delete the areas i don't want to emit but i'm still struggling controlling the flow rate.
Many Thanks in advance.
Have you tried to overwrite the velocity of the fluid in and around your emitter? This way the fluid can only flow out at (mostly) a fixed rate.
