Having trouble with vex espression for a tornado
2177 4 1- BlackBaloo
- 12 posts
Hi everyone ,
I'm quite new to houdini and i'm trying to make a tornado.
I first followed this tutorial https://www.youtube.com/watch?v=z19fxCbe2Eg [www.youtube.com] , wich gave me a nice swirling flow.
But my problem with that tornado is that it's swirling around the center and it's not really following our sweep mesh.
I want to make my tornado more like a cartoon tornado, thin at the bottom but wide at the top. So i need to make the normal go away from the center a little bit, because right know they are just going around it.
I think it's possible by changing or adding some lines in the Vex of the pointwrangle, but i don't know what to change Script is an alien language for me at the moment
Thanks for your help
- Moeen
- 36 posts
Hi BlackBaloo
I may have misunderstood exactly what you're going for, so please correct me if I'm wrong. I assumed you were wanting an ‘eye’ in the tornado as well as a tapering shape. I have attached a revised version of your tornado setup were I used a boolean to cut a middle piece out of the geometry used to generate the velocity; thus giving the ‘eye’. I also changed the ramp found in the ‘sweep_scale’ attribute VOP (that controls the shape). None of the changes were to the VEX code. Once again, I'm not sure if this is what you were looking for, but I'd be happy to help you if its still not quite right.
Attachment Not Found
- BlackBaloo
- 12 posts
- BlackBaloo
- 12 posts
Well, hello again ^^
I discovered a strange problem
I did a flipbook of the tornado and i discovered that the tornado stop around the 40th frame
There is no keyed parameter so i don't understand why it's stopping
I attached the latest version of the file, and 2 flipbook that show that the tornado stops at a certain frame
- BlackBaloo
- 12 posts
