Hi guys,
I'm trying to manipulate the last point of each curve being duplicated via the copy stamp sop and get it to snap to 0 in the Y coordinate but haven't succeeded in find a way to isolate the last point of each curve copy, was wondering if anyone could offer any advice in that direction ? : )
Thank you
Manipulating each copy from copy stamp sop
1322 3 1- GannBoonBay
- 2 posts
- Sean Rowe
- 39 posts
- GannBoonBay
- 2 posts
- Sean Rowe
- 39 posts
The foreach can either loop through Points/Primitives or attributes. The line by default is just one primitive so you can loop through without the class attribute. The attribute is useful when your geometry has multiple prims, for example if you dropped down a convert line sop between the line and copy sop your current setup wouldn't work as expected.
