RBD animated object interactions
964 0 2- Camisaur
- 3 posts
Hello! I'm new to Houdini and I've been working on an effect where some sort of weird bird crashes into a wooden beam, destroying the beam. I imported the bird with an alembic node, and in order to get the closest collision shell possible to its shape, I used a VDB from polygon node and exported that. Now, when I call in the VDB export through a static object node, I have all the animations and stuff but I cant find a way to make it interact with the beam. And if I call the VDB in a RBD node, I think I do have interactions but the animation is gone, even though it's set to “deforming object”. I'm not sure where I'm going wrong, and I could use some help…
