switch from lores geometry to hires and re-apply paint node.
   1211   1   0
Hi, i have a lowres grid and apply a paint node. After doing the painting , if i want to swtich the lowres with the hires grid, how can i do this and keep the paint di project on the same area (as on lores version) ?
Attribute transfer from the low res is probably your best bet. Paint sop seems to be point order based, so a different topology will mess up the application of the data.
cheers,
chrisg
