I have a simple HDA that is placing unreal instances along a spline. I'm trying to expose the instance path string as a parameter so I can switch the asset placed along the spline in unreal rather than pre-defining it in the HDA. This doesn't appear to work though. Is this functionality supported? I've verified the HDA working correctly when I just point it to a string rather than exposing it as a parameter.
Thank you for any information you can provide!
Exposing the unreal instance string path as a parameter in HDA's?
3088 2 0-
- nthompson
- 18 posts
- dpernuit
- 564 posts
Hi!
Could you share your HDA with us?
This should be working if you're exposing the unreal_instance parameter for example…
see here [www.sidefx.com]
You can also replace those instanced meshes in Unreal by drag and dropping assets on the Houdini Instanced Inputs in the details panel.
- nthompson
- 18 posts
