Hi guys , I have a small problem ,how to export geometry from Houdini to 3d Max
11281 11 2-
- space monster
- 6 posts
- goldfarb
- 3465 posts
- space monster
- 6 posts
Hi arctor ,thank you for your help and I tried it but did not work because Max does not
recognize the OBJ format and I tried in IGES format and Houdini makes it to big from1.2MB
in TIF to 12Mb in IGES and after importing the file Max start calculating and after 10 minutes crushed . Do you have any other suggestion ?
Thanks in advance
Anyone help me
Thanks in advance
Anyone help me
- edward
- 8081 posts
A quick google search shows this (OBJ2MAX and MAX2OBJ):
http://www.habware.at/duck6.htm [habware.at]
That website also has plugins for other versions of Max available as well. I can't try it though but maybe it'll work.
- Simon
- 2199 posts
space monster
Thanks in advance
Anyone help me
I suspect you were saving a poly model to iges, which won't work.
Polys -> OBJ
NURBS -> IGES
- djorzgul
- 235 posts
- space monster
- 6 posts
- Simon
- 2199 posts
Save it as OBJ and use that link that Edward posted to get the plugin for Max so it can read Obj's.
Alternative is a thing called 3dWin
http://www.tb-software.com/index.html [tb-software.com]
It only outputs 3ds files - and they have to be less than 3000 polys, but it's another option.
- Le_monkey_butt
- 166 posts
One thing you can also try it is using the Realflow plugin for Max and Houdini. Lately I manage to go between the 2 packages using the *.sd format. It can be tricky in the way that sometimes it doesnt work, making it not 100% reliable but when it does, it is sweet for deformed/animated objects. Works most of the time.
Time to get out of this messy world.
- goldfarb
- 3465 posts
- djorzgul
- 235 posts
- space monster
- 6 posts
Thanks guys finally I did it. By the way I found this link http://www.maxplugins.de/ [maxplugins.de]
Check it out.
Check it out.
