Hey! VOP has only Switch node, but it has single output.
My situation, then inside Foreach loop, sometimes I get wrong result, so I need to branch to either perform additional nodes, or go directly to loop end and cointinue looping.
VOP has no if_then node, if_else, or _branch or anything similar with multiple outputs based on condition.
Any idea to workaround that?
If_Then in VOP?
2689 6 1-
- assignators
- 44 posts
- tamte
- 9384 posts
you don't need more outputs for Switch VOP, it simply switches between False (0) and True (1) inputs or if you want even more inputs
the downside is that all of them get evaluated before switching
so alternatively
use If Block
also this can help:
https://www.sidefx.com/tutorials/h15-masterclass-loops/ [www.sidefx.com]
so alternatively
use If Block
also this can help:
- bollili
- 214 posts
I'm not at work so I can't verify but, did you have a look at this? http://www.sidefx.com/docs/houdini/nodes/vop/if.html [www.sidefx.com]
- assignators
- 44 posts
- tamte
- 9384 posts
- assignators
- 44 posts
Yes, but there is scenario, when I don't need any of inputs and just want to exit the loop, i.e. output should go directly to loop end. Hmmm, but maybe you are right, seems like I need somehow fully redo my node tree to accommodate switch usage
This is because sometimes both inputs are empty, and houdini hangs up in infinite loop. So I wanted to have several outputs to get out of this situation.
Edited by assignators - July 18, 2018 05:45:33
- tamte
- 9384 posts
