I am trying to use a COP as a “blend texture” of a “set length” guideprocess OP.
After some googlefu I came up with this possibilities:
(“out” is a null which is always the last operator in the network)
for absolute path
opimg/comp1/out/
for relative path
op:`opfullpath(“/img/comp1/out/”)`
Both of them I have typed into the “Blend Texture” filename path parameter field.
For some reason, it doesn't seem to work. I have used a simple black/white checker texture for testing purposes but without luck so far.
Would be nice if someone can point me to the right direction.
Thank you in advance
Daniel
Using COP as texture map in grooming networks
1119 0 1- blackpepperjam
- 1 posts
