I'm using a heightfield_output node, and I have “Divide into tiled maps” enabled, however it does not seem to work. No image is output and it never loads a status box. If I dive into the cop2net1 inside the heightfield_output, I see an error: “Cook Error in input: window1”
I'm using Houdini 16.5.496, and according to the changelogs:
Houdini 16.5.198 Fixed tiled output on Heightfield Output.
So presumably tiled output should work… Turning off Tiling does export a map.
Has anyone else run into this issue? Is this a bug, or something I am doing wrong?
Heightmap UDIM output
2551 2 0- nextheory
- 4 posts
- Simon Pagas
- 8 posts
- nextheory
- 4 posts
Update: If you are using EXR, make sure to use ‘Deep Raster’ for Output Type. That resolved my issue with exporting the UDIM tiles. However now I am running into an issue where my all of my channels are blank, except the height and bedrock channels. It writes the channels fine without tiling.
Any suggestions?
No UDIM passes:
UDIM passes:
Any suggestions?
No UDIM passes:
UDIM passes:
Edited by nextheory - Oct. 18, 2018 00:16:45
