Operator Path Parameter in Multi-Parameter block Doesn't work properly
5791
5
0
Nov. 6, 2018 2:47 p.m.
I am trying to add OperatorPath parameter in Multiparam block for processing multiple geometry but in Max whenever I am trying to add new param, it removes all the geometry added before it and have to again add other geometry in one go. Also Name of geometry also doesn't appear.
Thanks,
multiparam_operatornode.hda (6.0 KB)
BrookeA
Nov. 9, 2018 1:44 p.m.
Are you seeing this in Houdini 17.0.352?
Nov. 9, 2018 2:33 p.m.
BrandonA Are you seeing this in Houdini 17.0.352?Yes. I have attached the HDA m using inside 3dsMax.
Let me know if you need more info
Thanks,
Nov. 13, 2018 12:22 p.m.
Is this a known bug or m doing something wrong? Thanks,
BrookeA
Nov. 13, 2018 1:59 p.m.
The names of the objects not showing up in multi-parms is a known issue. I'm not able to reproduce the problem with the geometry being removed. Do you have steps for reproducing this?
Nov. 13, 2018 3:46 p.m.
BrandonA The names of the objects not showing up in multi-parms is a known issue. I'm not able to reproduce the problem with the geometry being removed. Do you have steps for reproducing this?Sorry I am not able to reproduce it. Maybe I clicked something wrong. Again Sorry.
Thanks,
