Master Material
   2682   3   1
Is there a way to create a master material and then use this material for other materials. I want to create one material and then use different texture displacement maps.
Best wishes,
Thomas
I imagine you could define the material as an asset, version it and all these instances will use the master definition with its own values.
Hi
If you want to build a generic material which can be use to make anyother material ofcourse you can, as all of materials inside houdini are open to change their source, so you can build any new materials very easily.
Even you have access to very low level functions such as reflect and refract in VOP to build your custom material from scratch.
But I wounder why you want to do this ?!
Because Houdini has some ready to use generic materials such as principle shader.
At least you may need to use them as a start point and just tweak them and add some more feature regarding your purpose.
Rabiee.Sadjad@Gmail.Com
Thanks! I did manage it
Best wishes,
Thomas
