In wrangle case,We can configure with setting the file VEXpression.txt in houdini17.0.
Python case,what should we do?
Does anyone know configure snippet of PythonSOP?
3010 3 0-
- Masaharu Izichi
- 4 posts
- Enivob
- 2660 posts
I have done it like this, from a shelf tool that generated a new python node. I found placing the code I wanted to install inside the doc string section of a def worked great.
The python text resides inside a string parameter named ‘python’.
def code (): """ import os,re,random node = hou.pwd() geo = node.geometry() lst_materials = [] is_material_missing = False """ node_python.parm("python").set(code.__doc__)
Edited by Enivob - Dec. 30, 2018 10:00:20
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
- Masaharu Izichi
- 4 posts
Thank you for reply,Enivob.
Your method looks like Maya.
So I don't want to use it.
https://www.sidefx.com/forum/topic/60332/ [www.sidefx.com]
I want python vesion of this method.
- Masaharu Izichi
- 4 posts
