Hi!
I made a wrangle that groups corner points from a treshold channel. I often have to re-write this node so I wanted to make an asset out of it. When I select that wrangle and do Asset -> New Digital Asset From Selection, nothing happens. When I duplicate that wrangle and select both the original and copy, I can create an asset.
Why do I need more than one node to create an asset?
-Olivier
Asset from single wrangle node?
2198 6 0-
- olivierth
- 1177 posts
- Andr
- 899 posts
- olivierth
- 1177 posts
- Andr
- 899 posts
sorry for the late reply,
in the parameter tab of your selected node there's that little gear you can click on to access some options relative to the specific node parameters.
There you can save and load back parameters presets.
If you do that in a wrangle node it will save the code typed inside the wrangle.
(The code you type in the wrangle is actually the value of a string parameter)
Cheers
Cheers
Edited by Andr - Feb. 7, 2019 04:30:36
- olivierth
- 1177 posts
- BabaJ
- 2164 posts
- goldfarb
- 3465 posts
