Hello-
I'm working through the soccer-ball tutorial, and I'm stuck at the part where it says “click on the Render tab and click on Polygons as Subdivisions (Mantra).” This is in part four, item 04 (page 51 in the book).
What do you mean by “Render tab”? Is this the “Render View” tab in the viewport? I made that assumption and clicked on that tab, but I don't see “Polygons as Subdivisions.”
Or is there some other “Render tab”? Maybe the top menu item which says “Render”? I tried that as well, and I don't see “Polygons as Subdivisions” there either. Do I need to look at the render node?
I'm surprised I've gotten this far, because the book doesn't have a lot of pictures, and when it says to click on something, it's easy for the beginner to have trouble finding the thing to click on. But all in all it's a pretty good tutorial, and I've learned a lot from it so far.
-Scott
Edit: OK, I found it, it's in the geometry object's parameter pane. I'll leave my post here anyway.
Soccer-ball tutorial: question, stuck on "render tab"
559 0 0- scottval
- 56 posts
