DOCS: RFE: special attributes and attribute access in all TOP node help cards
   2264   2   2
SOPs (where appropriate) and DOPs have standard “local var/attribute” explanation and lists, it would be very helpful to have this for TOPs.
It took me quite a while to figure out I couldn't access @Frame (which is what you'd guess from looking at the Info MMB) but needed to use @pdg_frame which was found eventually somewhere by searching the docs.
Having that stuff standard on each node's help card would be lovely.
Peter B
Peter Bowmar
____________
Done - should be available in tomorrow's build.
- Ken Xu
Thanks Ken!
Peter Bowmar
____________
