point attribute propagation
   870   1   1
Hi!!
I am new to houdini and this might be a stupid question but i didn't bfind any clear explanation on internet yet.
I'm trying to "extract some points from a grid to level them out from a box i'll be moving.
The choice I made was to use two opposing points from a box to delimitate the area i'll level and use a if statment to do the leveling.
But I can't find a way to use the point values correctly.
Here is what I did:
on the spreadsheet you can see that the minx minz mx and mz value are just set for the first point.
I tried putting a wrangle before that one to create variables or attributes but it doesn't change anything.
and as you can see, the for loop doesn't set the values right.
thanks in advance for your help
I am sorry but it is not clear what you are trying to achieve. Maybe an illustration or a HIP file would help understand it better.
