Rendering TOPs with Cmd
   7323   5   2
Hey Guys!
I am interesting is there any ways to rendering TOPs Network with Command line ?
I am really often using for ROPs something like that
SET hbatchDir="C:/Program Files/Side Effects Software/Houdini 17.5.173/bin/"
SET hipFile1=d_Jobs_/test.hip
SET ropPath000=/obj/Render_sim/Render
SET ropPath111=/obj/Render_sim/wedge_sim
CD /d %hbatchDir%
(ECHO mread %hipFile1%
ECHO render -V -I %ropPath111%) | hbatch
But now I am Using TOP NETWORK, how deal about that?
Thank You
We haven't added a command for rendering a top network like that yet. In the meantime you can use HOM via hython instead:
import hqueue.houdini as hq
node = hq.getNode("/obj/topnet")
disp_node = node.displayNode()
# blocking full cook of PDG
disp_node.executeGraph(False, True, False)
Yeah, this is works good inside Houdini pythonShell
Damn just spend all day to try run python code on windows10 outside Houdini and its fail
any help please
>>> import hou
File "<stdin>", line 1, in <module>
ImportError: No module named hou
so the idea just build 2 files with py and bat
py file with
import hou
hou.hipFile.load("d:/_Jobs_/tests/test.hip")
node = hq.getNode("/obj/Render/topnet1")
hou.node("/obj/Render/Render").render()
and run with bat file
"C:\python27\python.exe" "d:\_Jobs_\tests\RenderHoudini_TOPSsdasda.py"
pause
Edited by cool1986vfx - April 16, 2019 12:34:00
You'll have to run that with hython, not python:
%hbatchDir%/hython.exe "d:\_Jobs_\tests\RenderHoudini_TOPSsdasda.py"
oh yes yes! This is exactly what I am looking for! Thanks @chrisgreb
Btw, I am have right now two files and they are looking like that
file RenderHoudini_TOPS_Render.py
import hou
hou.hipFile.load("d:/_Jobs_/tests/RenderHoudini_TOPS.hip")
node = hq.getNode("/obj/Render")
and for Trigger
file RenderHoudini_TOPS_Render.bat
%hbatchDir%hython.exe "d:\_Jobs_\tests\RenderHoudini_TOPS_Render.py"
and is there any way it make smarter for example
merge and keep in one file
and one more what the best way to change range of Rendering without open Houdini
Thank !
Edited by cool1986vfx - April 16, 2019 15:26:52
Take a look at HOM reference and you can also look at what we do in $HFS/houdini/python2.7lib/pdg/job/rop.py
hou.hipFile.merge(...)
hq.render(node, (start,end,increment))
