Hi guys
I have a fairly high res flip sim (by student standards, about 3 gig per frame) and I needed to cache it out as a .sim to utilise checkpoints
I need to read this simulation in using playback simulation on the dopnet and a dop IO node with the flip presets in order to pull in the velocity fields for a whitewater sim, however when I do this the computer gets stuck on the first frame I load in.
My only current solution is to go through every frame, unticking and reticking the playback simulation button which would take me 2 minutes of load time per frame for 432 frames.
An alternative I've considered is the Houdini python module however I am not familiar with this and don't know if the required functions exist.
Please could someone with more knowledge on this tell me if this is possible in the python module or whether there is an alternate solution such as a way to pull velocity fields from a .sim cache
George
Issue with playing back flip sim on low ram( 32gb) computer
337 0 0- coleclough
- 4 posts
