Is it possible to move around drawn hair guides while making sure their root are sliding on the surface? This should ideally be possible on the Guide Draw node itself; otherwise it can make quite a busy graph. I can select and transform guides but that's detaching the root from surface which is useless.
On a side note, even though the skin group is specified, Guide Draw still draws guides on other groups that were not specified. Is that an expected behavior?
