What I'm trying to do is the setup scenes in an automated way with Python (node creation, setup, rendering). So, all good except for 1 part and that is the texture baking with Mantra.
Python is running and managing the renders being fired up. Between 4-6 Mantra's get started if there's space. All good, except for usually 1 mantra to start up, eat 3/4 seconds of CPU time and then idles at 175 MB memory used.
After 30 minutes when all other renders are finished, there's usually 1 still idling.
The weird thing is that when I close/force close Houdini, the idle Mantra actually starts working and render succesfully.
Also, if I would force close the idle Mantra process, go into Houdini and fire it up manually by pressing the button, it also renders succesfully.
Any thought on how to troubleshot / fix this?
Python to Mantra rendering, all mantra's rendering -1
938 0 0- paleoPixels
- 26 posts
