The problem is that each workitem seems to be a separate command, and therefore a separate houdini process. I'd like to batch each wedge together, into the one houdini process, so I don't suffer the houdini startup and scene cook time penalty each frame.
I'm new to TOPs and find it all a bit confusing but it seems like the ‘All Frames in One Batch’ option on the ROP Fetch could do what I need. When I generate the work items they seem to be doing what I need (the work item command represents a frame range, not individual frames), however when I cook the TOP, all my work items fail with this python error:
Loading .hip file C:/myfilepath/waveforms_v04.hiplc.
File "C:/myfilepath/pdgtemp/47396/scripts/rop.py", line 500, in
cooker.cookBatchFrames(args)
File "C:/myfilepath/pdgtemp/47396/scripts/rop.py", line 253, in cookBatchFrames
""".format(args=args, index_expr=index_expr, parm_name=parm.name())
AttributeError: 'NoneType' object has no attribute 'name'
[Redshift] Closing the RS instance. End of the plugin log system. I've tried it with fetching a mantra ROP and it seems to work ok. I'm using Houdini 17.5.173.
thanks
