Subdivide SOP On a SIngle Axis
2889 1 0- NichoReynolds
- 4 posts
So I have an established group of non adjacent primitives that I want to divide into two equal pieces, so my first thought was to utilize a Subdivide SOP but Subdivide, as far as I can tell, divides on both a horizontal and a vertical axis, and I would ideally like a solution that lets me choose a single axis. I am willing to look into VEX if there isn't a node that does what I am looking for, but if that is the best way forward I would love to here any advice on a solution. Most of what I have found on splitting a primitive in VEX looks a bit nightmarish. Thanks for taking the time to answer.
- Andr
- 900 posts
divide sop has a bricker polygons parameter that can be helpful.
Check the this example file, It's NOT an efficient method. And you might need to work a bit to implement it for your needs.
But it could be a starting point..
I would like to know a better solution,
cheers
cheers
Edited by Andr - June 20, 2019 15:23:19
