Hi !
I'm currently processing some cloths over shots, meaning I have a simulation part of process and graph, and a warp part.
All of the shots are driven with csv and I want to be able to say for this shot I want sim+warp, or this one just warp and so on.
But after a lot of tries I can't find a way to switch efficiently, or bypass some part of graph:
- Switch can't take expressions
- For some reason a split make my rop_geom crash right after.
How can someone bypass some part of graph then ?
Thanks !
Alex
Switching/Bypassing
2686 5 1-
- SirAlucard
- 18 posts
- seelan
- 571 posts
Split node with an expression is what I would recommend. We used it for the PDG Environment demo for skipping terrain erosion and road building on certain terrain tiles.
Do you have a crash report or any error/log info you can provide?
Try the split node with a simple case and see if it works.
Which version of Houdini are you on? Try with a newer daily build.
- Andr
- 899 posts
- SirAlucard
- 18 posts
I'm using 17.5.293. Split seems to work but I finally did a different way which might be more of a PDG way of doing things, ie separating jobs at first and then doing the chains even if I had to duplicate the parts of sim and warps which I wanted to avoid in the first place but well at least it work.
Regarding the rop crash, haven't retried but I wouldn't be surprised if it was tied to a strange behavior I noticed, sometimes things crash or don't work well. Then you save and somehow it seems to flush things and make things going on well. Don't know if it's me just tired or something happening
On a sidenote, is there any more case study examples on the way about PDG ? Like the ones from the launch event for example. I really believe some of my problems comes from a bad use of the graph (for example trying straight away a switch as usual when it's not the way to do it here) and that would be great to have more concrete examples for specific tasks
Thanks for your answer !
VFX Artist
UNIT Image - Paris
UNIT Image - Paris
- kenxu
- 544 posts
- SirAlucard
- 18 posts
