Need help with DOP hard constraint (condof=1)
2348 4 1- RadikSalakhov
- 27 posts
I made a simplified example where a box is thrown in direction (1,1,1), but it should stay in plane YZ, because of hard constraint which “condof” is set to “1” and “condir” is set to “(1,0,0)”.
It works until the box interacts with another object in the scene (e.g. ground). Then it returns somehow to the initial anchor position.
I attached hip file and video which shows the problem.
I spent a lot of time and tried a lot of different options, but nothing seems to work.
What do I do wrong?
What do I do wrong?
Edited by RadikSalakhov - Aug. 25, 2019 12:56:07
- N-G
- 209 posts
Hello!
I've created something like Angry Birds destruction before.
Please take a look at here:
2D Rigid Body Simulation [vimeo.com]
- RadikSalakhov
- 27 posts
Thanks a lot for this great example. In my case it is not enough just to set “Z” coordinate to zero each frame. I need some constraint which holds objects on specific plane (or line).
In the attached example a robot moves on plane YZ before bouncing off the ball, but it is carried away from the plane after it bounce off the ball. I need it to stay always on that plane.
There are cone twist constrains which holds parts of the robot together. If I manipulate position manually (like in your example) then constrains start to behave oddly (robot parts are moving away a little bit).
In theory hard constraint with anchor (condof=1; condir1,0,0)) should do the trick, but it doesn't work.
Edited by RadikSalakhov - Aug. 27, 2019 13:51:27
- N-G
- 209 posts
- RadikSalakhov
- 27 posts
