Python function?
1972 10 1- Shadowjonny
- 97 posts
- krueger
- 191 posts
- Shadowjonny
- 97 posts
mkpshou.parm('/obj/blah_blah/null1/parameter_here').eval()
If you're using the script in the same node as the parameter, you can also this where hou.pwd() means the current node:hou.pwd().parm('parameter_here').eval()
Im quite new to python.
nodefolder = hou.parmTuple('/obj/subnet1/ProceduralEletricPole_Setup/Control/folder2').eval()
So this gets the number of parameters it gets from Parameter folder2(its a multiparm block). How do i get the name or value of each parameter in the parmTuple.
- krueger
- 191 posts
Ah, I missed the multiparm block part. You'll have to find out what the name of that “Placement1” parameter is either looking in the parameter interface, or just drag it into a python shell. In the example below I just called it “parm_name” and each new one gets numbered (1, 2, 3, etc).
If the number of parameters changes, you can do something like this to loop over the number of parameters:
Or if they're static you can just change the number on the end of the parameter:
numParms = hou.parm('/obj/geo1/null1/folder0').eval() for i in range(1, numParms + 1) : parm = "/obj/geo1/null1/parm_name" + str(i) print hou.parm(parm).eval()
hou.parm('/obj/geo1/null1/parm_name1').eval() hou.parm('/obj/geo1/null1/parm_name2').eval() hou.parm('/obj/geo1/null1/parm_name3').eval()
- Shadowjonny
- 97 posts
mkps
If the number of parameters changes, you can do something like this to loop over the number of parameters:numParms = hou.parm('/obj/geo1/null1/folder0').eval() for i in range(1, numParms + 1) : parm = "/obj/geo1/null1/parm_name" + str(i) print hou.parm(parm).eval()
Or if they're static you can just change the number on the end of the parameter:hou.parm('/obj/geo1/null1/parm_name1').eval() hou.parm('/obj/geo1/null1/parm_name2').eval() hou.parm('/obj/geo1/null1/parm_name3').eval()
Thank you for the help. Not use to python how it reads its function or what to put in the parameter for the functions, use alot more vex to use to c++. xD
- krueger
- 191 posts
- Shadowjonny
- 97 posts
mkps
No worries. Did you get yours working?
node = hou.pwd() geo = node.geometry() geo = hou.pwd().geometry() pts = hou.pwd().point() numParms = hou.parm('/obj/subnet1/ProceduralEletricPole_Setup/null1/folder2').eval() for i in range(1, numParms + 1) : parm = "/obj/subnet1/ProceduralEletricPole_Setup/null1/PlacementParameter" + str(i) value = hou.parm(parm).eval() if geo.findPointAttrib("ValuePt") == 0: #Find if Point Attrib ValuePt exists geo.addAttrib(hou.attribType.Point,"ValuePt", value) else: #If it does just set the value in the same attrib pts.setAttribValue("ValuePt", value) print value
Error im getting: ^^^^^
AttributeError: ‘SopNode’ object has no attribute ‘point’
node = hou.pwd() geo = node.geometry() geo = hou.pwd().geometry() numParms = hou.parm('/obj/subnet1/ProceduralEletricPole_Setup/null1/folder2').eval() for i in range(1, numParms + 1) : parm = "/obj/subnet1/ProceduralEletricPole_Setup/null1/PlacementParameter" + str(i) value = hou.parm(parm).eval() geo.addAttrib(hou.attribType.Point,"ValuePt"+ str(i), value) print value
With this i dont get any error, but i get more Attribs made. I just want 1 attrib made and for each point give it the value. Srry im bad at python xD
Edited by Shadowjonny - Aug. 27, 2019 01:16:13
- krueger
- 191 posts
Your ‘point’ error was because it should have been
But here is your script modified a little to work:
pts = geo.points()
node = hou.pwd() geo = node.geometry() target = "/obj/subnet1/ProceduralEletricPole_Setup/null1/" numParms = hou.parm(target + "folder2").eval() attrib = "ValuePt" if geo.findPointAttrib(attrib) == None : geo.addAttrib(hou.attribType.Point, attrib, 0.0) for i in range(0, numParms) : #Start at 0 because ptnums start at 0 parm = target + "PlacementParameter" + str(i + 1) #Offset parm number by 1 cause parms start at 1 value = hou.parm(parm).eval() pt = geo.point(i) pt.setAttribValue(attrib, value) #print value
- krueger
- 191 posts
I forgot to add a safety check so it won't fail if the number of points is less than the number of parameters. This one fixes that.
node = hou.pwd() geo = node.geometry() pts = geo.points() target = "/obj/subnet1/ProceduralEletricPole_Setup/null1/" numParms = hou.parm(target + "folder2").eval() num = min(len(pts), numParms) #Check if number of points is less than number of parms attrib = "ValuePt" if geo.findPointAttrib(attrib) == None : #Check for attrib and add it if it doesn't exist geo.addAttrib(hou.attribType.Point, attrib, 0.0) for i in range(0, num) : #Start at 0 because ptnums start at 0 parm = target + "PlacementParameter" + str(i + 1) #Offset parm number by 1 cause parms start at 1 value = hou.parm(parm).eval() pt = geo.point(i) pt.setAttribValue(attrib, value) #print value
- Shadowjonny
- 97 posts
mkps
I forgot to add a safety check so it won't fail if the number of points is less than the number of parameters. This one fixes that.node = hou.pwd() geo = node.geometry() pts = geo.points() target = "/obj/subnet1/ProceduralEletricPole_Setup/null1/" numParms = hou.parm(target + "folder2").eval() num = min(len(pts), numParms) #Check if number of points is less than number of parms attrib = "ValuePt" if geo.findPointAttrib(attrib) == None : #Check for attrib and add it if it doesn't exist geo.addAttrib(hou.attribType.Point, attrib, 0.0) for i in range(0, num) : #Start at 0 because ptnums start at 0 parm = target + "PlacementParameter" + str(i + 1) #Offset parm number by 1 cause parms start at 1 value = hou.parm(parm).eval() pt = geo.point(i) pt.setAttribValue(attrib, value) #print value
Thank you for the help. This is helping me understand more about python. Also is it possible to make a array attribute?
- krueger
- 191 posts
