Stuck need some enlightenment
801 0 0- Shadowjonny
- 97 posts
So i got a Null that as a folder and is a multiparm block with a integer value in it. I want each integer parameter to be assigned to a point number that is created. Tried adding the point just made into a pointgroup function and with different number at the end of the group name but it only does it for that current point and theres nothing for the last few spawned. Should i keep trying this with Vex or ill python be something better to use for Parameter change?
Edited by Shadowjonny - Aug. 26, 2019 13:48:05
