Hi all,
I have been playing around a bit with LPEs and I have run into a stumbling block. The issue is for a given light(Sphere or Env or Area) with “Render Light Geometry” enabled… is this considered as part of incandescent? As the default LPE VEX Variables of “lpe:CO”(direct incandescent) and “lpe:C.+O”(indirect incandescent) both return black AOVs for any given light that I have been testing. So, again is a given light considered part of incandescent when “Render Light Geometry” is enabled or is this a bug or am I missing something?
P.S. Using the default VEX Variables of direct_emission or indirect_emission in my ROP work but it does not allow me to split out two or more lights with “Render Light Geometry” into their own AOVs…
Thanks ahead of time for the help.
Kind regards,
Mark
LPE for lights using "Render Light Geometry"
4175 6 2-
- mwnorrie
- 7 posts
- dlee
- 477 posts
Hi. Lights use “L” token. “O” refers to emissive objects, not direct light sources. To put contributions from one (or more) light into its own AOV, you need to assign an LPE tag to the light (look under light's parameter pane, look for “LPE Tag” parameter), and write an expression that ends with the light with the tag.
https://www.sidefx.com/docs/houdini/render/lpe.html [www.sidefx.com] has more information (search for ‘tag’. there are also example expressions that use tags.)
- mwnorrie
- 7 posts
Good afternoon,
Thank you for the quick response… Just to clarify this topic, I have attached an image showing the results I am seeing. From what I understand when you enable “Render Light Geometry” on a light the output is incandescent(direct_emission) as you can see in the attached image. So, I just wanted to double check this as I am not getting the results I expected with the LPE and I think it could be a bug.
P.S. If this is not a bug then could you please kindly let me know what the LPE should be for this example.
Kind regards,
Mark
Kind regards,
Mark
Edited by mwnorrie - Sept. 26, 2019 19:40:25
- jsmack
- 8178 posts
dlee
Would the expression for all lights' direct rendering be
lpe:CL?
- dlee
- 477 posts
- pbowmar
- 7046 posts
- jsmack
- 8178 posts
