Filmbox FBX import duplicates material for every objects...
701 0 1- Tatsuman
- 4 posts
Hello, I imported FBX file by using File>Import>Filmbox FBX and the material gets duplicated for every single object. I wonder if there is a way to not get the material duplicated. Importing the same FBX to C4D doesn't cause this problem and in FBX text file there are only two material definitions. Does anyone know any solution? Thank you in advance.
