Hi Guys,
I am new to Houdini. Watched a lot of tutorials, but still can't find a way to project road onto surface / height field.
To be more correct I can protect a road mask or road geometry, and it follows the main surface curvature. Which is fine.
What I want is that roads cross section stays horizontal?
Thank you
Flat Road projected onto surface / topography
7260 5 0-
- artpen
- 2 posts
- vusta
- 555 posts
just thinking outloud, lets' take the lower road that you've marked, make that ‘level’ if you drive along that road to the T section, the road infront of you MUST go ‘up’ so how does the ‘level’ road there you started from match up with the road going ‘up’ infront of you ? so it must gradually twist from being horizontal to 45 degs when it gets to the T section ?
- Nicolas Longchamps
- 37 posts
- artpen
- 2 posts
- Jerry Hat
- 30 posts
This tutorial by HoudiniKitchen is just what you want:
I really like these set of tutorials, they're very thorough and clearly explained. Fills a lot of holes if, like me, you've learnt Houdini piecemeal.
- blog: http://www.jerryhat.com [www.jerryhat.com] - usually features Houdini these days
- DimaVJ
- 3 posts
I think this tut gives a complete solution
https://www.youtube.com/watch?v=l4Z0X20ikSw [www.youtube.com]
