Send command and how to read work_item data
   1931   2   1
Hi guys,
I'd like to understand how to read attribute attached to a work_item from a “sendcommand” node.
For example:
I have a “houdiniserver”,connected to an “attributecreate”, connected to a “sendcommand”.
The “attributecreate” node has 1 string attribute, with ‘name’ as stringname1 and ‘Marco’ as stringvalue1.
The problem is: how can I read stringvalue1 in the “sendcommand” node.
I tried work_item.stringData('name', 0) … work_item.data.stringData('name', 0) … work_item.data('name', 0) … hou.parm('../path/to/attrib') but I can't get that data.
Is there any concept that inhibit that flow of data?
Thanks in advance,
Marco
Try this:
s = strData(work_item, 'stringname1', 0)
chrisgreb
Try this:
Thanks a lot Chris!
